Originally Posted by The Radium King
don't think the lsd's will xfer. gilles has a 987 6-speed unit that would work for you if you do the switch. you will have to change axles *i think* as the 987 unit is shorter, requiring shorter axles.
if you do go ahead w it, i 'd be interested in your 986 lsd.
Hmm - didn't know about the axles not working - need to look into that - same with the LSD. UGH. Apparently the 987 trans is much beefier....
