Old 11-05-2018, 02:19 AM   #9
Troy.Boxster
Roll bar mesh inserts won't fit in a 210x210mm square, not to mention that 3D prints of them would not hold up well (too much stress, not solid enough). Best to just make these out of perforated aluminum sheets.
It definitely won't fit in a 210x210 square, but MIGHT just fit in a 210x210x205 cube if the design is wedged into opposite corners. However, the support structure necessary to actually print the thing like that (if at all possible on a typical home unit) may make it far more complex to design and print and a pain to clean up and smooth out. And, you are probably correct with the longevity, but it might be interesting to try if someone is looking for a challenging project.
2000 Boxster S - B.A.D. short shifter and intake plenum - 996 throttle body - Fred's xenon projector headlights - blue LED instrument cluster - and a few other things
Driving this car makes me wish I lived farther away from work!
Troy.Boxster is offline   Reply With Quote
