Old 11-04-2018, 03:52 PM   #2
truegearhead
truegearhead's Avatar
I can’t speak to the left side but once had a cam plug fall out of the right side of the motor and it pumped quarts of oil out in a matter of seconds. Odd that you can run without them. That being said if they popes out it’s more than likely a pressure problem which points to the AOS. Id replace the AOS and the plugs (MAKE SURE they are well hammered in, not like your photo) and then send it.
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
truegearhead is offline   Reply With Quote
