I'm missing something here. 10 How did you determine which green plastic bushing to work on? does it matter? the one in the photo looks just like mine....not broken or damaged but the bottom one is accessible, the top not. 2( how did you get down to the bare wire cable? the cable has a thick plastic and metal housing it slides through. It seems that the cable is wrapped around a pulley that is covered on the outside and I don't see how to get to the bare cable to get the split clamp on it. Will the clamp simply thread itself into the green plastic bushing? What does the plastic tie do? I need some help please
Reason: left out words
