Thread: 6 speed in 2.5
Old 11-02-2018, 02:52 PM   #15
deathsled986
Originally Posted by Racer Boy View Post
You are right, there is a reason why that isn't done. You'd also have to change the ring gear if you change the pinion gear (they have to mesh to each other; if you change the ratio, you change the number of teeth, and no more meshing of gears).
Changing the ring gear is a piece of cake. I think it's pretty much understood that if you change the pinion gear you also have to change the ring gear. That in itself is not a reason why the pinion gear isn't easily swappable.
deathsled986 is offline   Reply With Quote
