Old 11-01-2018, 07:46 AM   #17
maytag
Who's askin'?
maytag's Avatar
It is a tiny oil passage at the top of the head. When you pull the green plugs you should be able to see the end of a camshaft, they are tubular& sealed with a 1/4" expansion plug. Make sure that plug is intact. If that head oil passage way is blocked the pressure can blowout the cam plug. Edit, just realized Quadcammer already posted half of what I stated.
Hmmmm..... this is good info.
Couple questions:
1. is the green cam plug the same plug used on the OTHER end of the intake cam? The missing plug is the one above the scavenge pump on the left side. I don't see more than one cam plug listed on pelican.
2. Are you suggesting that this is a wet plug? That if it's removed there would be oil leaking? Because there is no sign of oil around the crooked plugs, nor is there any sign of it around the hole that seems to be missing the plug altogether.
