Old 11-01-2018, 07:18 AM   #13
Gilles
My thought at that point was that there was probably plenty of oil that needed to burn off. So I fired it up again in the driveway. it fires immediately, but idles rough. When you rev it, it smooths out.
so I went to the right side; 150, 155, 152.
So I went back to the left side: 153, 150, 152.
Hello Maytag,
IMHO these are great news..! (way better than the original prognostic)
Your engine has pretty good and even compression (w/less than 10% difference between cylinders), I would remove the intake plenums to clean them properly and perhaps cranking it a bit more with the plugs removed to remove as much oil residue as possible, then reinstall the plugs and run it until the smoke goes away.
Did you check the vacuum to see the AOS condition? I have an extra (used) AOS in good condition removed from my 987S that you can have it if you want, shipping it should be a few bucks..
Again, these seem to be optimistic news, good luck!
Gilles is offline   Reply With Quote
