Old 10-28-2018, 09:09 AM   #24
Todd Mac
Todd Mac's Avatar
As far as additional parts, I believe new caliper bolts are recommended and the originals have a star type pattern so a special socket to remove them - and the new ones have an allan looking head so another special socket for that. (I picked the sockets up at Lowe's for ~<$3 each).
Also, you may want to get new brake wear sensors as I broke one taking them out (~$10< each).
I also bought the damping pads, which you may or may not need/care about but it's another item you would do since they old ones (on my 04 S) came out attached to the pads and were not reusable. I don't recall if the base brakes use them but I think they may not.
I reused the rotor screws the hold the rotor in place while you re-install the lugs. And I re-used the pin and metal pressure piece that holds the pads down (mainly because that part didn't ship with the rest of my items and I'm impatient).
I didn't do the rears yet but I believe the same will be needed there (though the damping pads are different).
Good luck.
2004 S
Todd Mac is offline   Reply With Quote
