Old 10-27-2018, 02:39 PM   #15
mgfranz
Your new alignment specs look good and will maximize your car for stock suspension running dual purpose street/rack use, with much better tire wear. It shout turn in better and feel more planted in a high speed 3rd gear sweeper. Now to add some tires with more dry grip that hold up well to continuous lapping.
I agree that the lower stress bar is the wrong tool to add negative camber to the rear. The front is where added camber pays the greatest benefits anyways. Fix that first, then evaluate the rear.
The rear stress bar will have to be fully evaluated at the track, but the development of it was mainly to tighten up the rear and solve a potential weak point in that aluminum pan.
Tires may have to wait, just put on a new set of Falkon Ziex 950 to try.
mgfranz is offline   Reply With Quote
