The panel behind the seats is easy enough to access, but with seats in place access to engine is a bit of a pain...you'll find that removing the seats is your best option. If your planning to do any wrenching in the future, I'd suggest that you might want to check how easy your seat bolts are to remove; you might want to go ahead and remove and replace bolts now (to make sure they aren't seized) so you don't spend a bunch of time later trying to remove seat bolts just to get to engine panel.
