I generally start at 28 cold all around and adjust to 35 hot all around. This is with street tires or NT-01s.
Hot pressure as you come off the track is the important bit. Cold pressures may vary 3-4 psi depending on the heat of the day and whether you drove off a trailer or drove the car to the track.
