Old 10-22-2018, 07:15 PM   #16
rexcramer
1997 Tip, 2018 Macan
rexcramer's Avatar
Probably not. It will all depend on the low temp you are starting from. Set the timers to come on +/- an hour before you plan to start and see if that is enough. As others have suggested, insulation is cheap and easy to install. Our 2 heaters raise the condo's 670 SQFT 15 degrees in 30 minutes. But we are starting at +/- 50 F.
The link will help you calculate your electrical costs. https://www.saveonenergy.com/energy-consumption/
Originally Posted by jaykay View Post
These look like they might be pretty efficient......do you think they would be able to heat up a single car garage with an insulated door in 30min? One wall and ceiling are common to living space. What did they add to your electricity usage? I am thinking I am not going to try to work in -20 C.....maybe these will be enough.
I have used smaller units like this. There is no fan, open element, or ombustion, very neat and tidy
