Old 10-22-2018, 10:58 AM   #13
CdnRD
Do you have a door from the inside of your house to the garage? I will prop mine open for an hour or two before I work in the garage in the winter. It can raise the temperature a good 10C and takes the bite off. I've got a pretty good electric 240v heater but it's not nearly as fast. Keep in mind that there's probably way more moisture in your house than in your garage so you wouldn't want to do this all the time. I make sure the door is closed before I start working if I'm using chemicals. Obviously running the car is no good door open or closed. Our garage is well heated and rarely goes below freezing though.
CdnRD is offline   Reply With Quote
