Old 10-22-2018, 05:40 AM   #11
rfuerst911sc
My humble opinion: you will be wasting your time with small electric heaters all that will happen is your power meter will spin like a router . You are in Canada and I'm assuming many days/nights are far below 0 degrees . So EVERYTHING in the garage is cold and you have to overcome that . Like others have said insulate , insulate and insulate . That includes walls/ceiling/garage door . Then for heat I would go with an LP or natural gas VENTED heater these are generally hung from the ceiling . They pull in outside air for combustion and obviously exhaust outside . You need a massive amount of heat for lets say 10 - 15 minutes to overcome all the cold then you can dial the heat back to maintain your comfort level . Do it once and do it right you won't regret it .
rfuerst911sc is offline   Reply With Quote
