Old 10-21-2018, 10:46 AM   #1
rfuerst911sc
Any thoughts of installing " flats " on either end of the tube to allow a wrench to turn/adjust vs. the knurled section you currently have ? I picture the car being on an alignment rack with the holes in the aluminum plate being slotted . Loosen the nuts/bolts on the aluminum plate and now adjust with your cross bar to whatever alignment spec's can be achieved . Tighten down the secondary nuts on your bar and then tighten down the aluminum plate hardware . Is that the general idea ? I'm thinking turning the bar with a wrench vs. your finger tips on the knurled section would be easier . Just thinking out loud .
rfuerst911sc is offline   Reply With Quote
