The first time does take a while to get everything set up. Put marks and shim sizes on the floor so you don't have to futz around the next time to level the scales.
If you are corner balancing you need to disconnect the sway bars and put your shocks to full soft. Set the ride height first, corner balance, camber then toe.
You look like you are doing great, just keep chugging.
