Old 10-21-2018, 07:16 AM   #1
mgfranz
Originally Posted by rfuerst911sc View Post
Where are you installing the flat washer ? Under the bolt head or between the flat of the heim joint and the suspension ear ? I assume you are " pre adjusting " towards the outside then installing the aluminum plate ? A little more detail please . Thanks
The washer goes under the bolt head to prevent galling of the bushing and the heim joint. As far as pre-loading, I initially installed it nuetral, but I will be playing with it once I get to the track. I want to get over to the alignment shop and see what the best setting would be.
mgfranz is offline   Reply With Quote
