Old 10-18-2018, 03:39 AM   #18
mavis.d
mavis.d's Avatar
Originally Posted by CDNIcecube View Post
Hi all,
I am confused. It seems we have to sand the outside of the lenses , so why having to open it (in an oven, etc.)?
For those who use a sanding pad on an electrical drill, can you list the sequence /profession of the grit you used to ? I.e 30, 60, 80, etc?
Thanks!
When I did them, several sets I, I used a sander I know others use different methods. I used sanding discs on a drill and started with 36 and went to 1200/1500 then paste and polish. 36,80,120,180,300 etc
Opening the light allows you to re-paint the reflector under the indicator as it is a gold colour painting a darker colour gives a more factory look
mavis.d is offline   Reply With Quote
