Old 10-17-2018, 06:22 PM   #16
Turbodad
Originally Posted by Porsche-Eh View Post
That’s just an ordinary time for a new battery issue. If you put in a new battery and it does that, time for a new starter.
Installed a new battery it started. let it sit for a few minutes because the AOS tube had come loose and it would not start. Changed the starter last week. Checked relays and fuses. I installed a matched set i got a few years ago with a swap engine and no joy...
There is an electrical connector in a black plastic box in the engine compartment. I would call it a "ground" but I believe it is a positive terminal. When I turned the key and wiggled the cable the car started. I sprayed the connection/nut with a little battery cleaner, loosened/tightened the nut and the car works perfectly after eight months. Also I did have a warning sign in that the gas cap would not lock consistently before it went completely "no start"". So now all is well...the little things...sigh ....
2001 Base with 2002 3.2 DIY swap 97 "short shift" tip "Joe Toth" aerodynamics, Z top, painted headlights.
2001 Boxster 5 speed
Turbodad is offline   Reply With Quote
