Old 10-15-2018, 08:45 AM   #2
jaykay
jaykay's Avatar
I'm going to flush my brake fluid... read/saw the instructions/directions ready to proceed. Waiting on the ordered Motive bleeder.
I'm also going to install SS brake lines. I'll remove the brake fluid cover and remove/install the lines trying to mitigate fluid going all over the place. Waiting on the flare nut wrench set.
My inquiry...
Should first I install the new lines then flushing the fluid with new? Or... flush the fluid with new... install the new lines... then "top off" the fluid?
I appreciate any guidance, tips, and tricks. Thank you.
I think you would be wasting time and fluid flushing before hand unless there is some specific reason. You are going to lose a lot of fluid during the bleeding process ......might as well combine the flush and bleed after the line change....just my opinion
986 00S
