Old 10-14-2018, 05:46 PM   #3
elgyqc
elgyqc's Avatar
Originally Posted by Brian in Tucson View Post
You have one bent rod (the upper one in the pic.) You can straighten it with a hammer and a acetylene torch. I probably wouldn't, I'd be looking for one rod on Ebay. Then when you put it all back together with new cups, make sure each rod is exactly the same length from where it connects to the transmission to where it connects on the top. Both sides should be identical & interchangeable, same exact length for both. And synchronize the transmissions, you can turn the right transmission with an electric drill connected to the cable where it attaches to motor. Pelican's writeup about rebuilding the transmissions is pretty good and goes into all this stuff.
I will suggest this, when they go wrong, they can be a major pain in the butt to get back to correct. Mine had bent rods, at least one clamshell carrier, and a stripped gear in the right transmission. Still trying to get it so that it doesn't bind or pop. And trying to get the clamshell to close flat on the right side.
I feel your pain, good luck bro!
I have been using it manually for a couple of days now, works fine with no stress about things breaking.
Thanks for the pointers... if I decide to repower the roof next Spring I will follow your advice for syncing.
Grant
