Old 10-14-2018, 12:35 PM   #2
speedyspaghetti
Originally Posted by Boatin View Post
Hi BoxsterSteve,
Can you tell me more about the 'relearn process' ?
IIRC - you lower the window all the way, hold the button down for 5 seconds, and then raise the window all the way and also hold the button for 5 seconds while it's at max height. That should do the trick.
However, for me, I had to replace the regulator since the relearn trick stopped working for me after a few months. It's not a hard DIY - just a little finnicky. Can definitely be done though. I used the URO part because I'm cheap. It has held up fine for the past 10 months.
speedyspaghetti is offline   Reply With Quote
