I'm afraid if you put in 10 quarts you may have overfilled it. The most I have ever gotten in is maybe 9+ after dropping the sump.
The display will give you some guidance but I rely on the dip stick. It is hard to see fresh oil levels. Lay the end indicator on a paper towel to help see the level relative to the fill lines. If you do find it over filled, you can remove some by draining the filter canister
Seal Grey
