Old 10-11-2018, 08:25 AM   #1
Geof3
Originally Posted by elgyqc View Post
Thanks fellow Oldcarguy, it seems I didn't do my homework on this one. Only after reading your comment did I see a customer review on the site where I bought the metal replacement cup explaining the reason for using plastic. I have ordered a set of plastic cups. My repair philosophy is to do as much as I can myself and reuse the maximum of old parts, so I was able to reform the bent pushrod. That's me not a reflection on others who prefer shiny new parts at all times. For example, against all advice, instead of buying a rebuilt unit I resealed the steering rack on my 928. No leaks yet so I am happy with that decision... so far.
I did repair the the right side drain tray, it had a hole in it that I assume happened when the end cup broke. The reason I started investigating the roof was that I was getting water on the floor behind the passenger seat.
While I appreciate your desire to use and rebuild parts, this is one area where that is a bit of a mistake. Once again, given that the rod is already bent, illustrates an issue. It is probable the bushings are shot and causing binding or some other issue. This is truly one area where new shiny parts are going to be your best end result.
