Old 10-11-2018, 04:15 AM   #1
Oldcarguy
Oldcarguy's Avatar
Just a note that the plastic end cups are designed to break if the roof system binds, thereby saving more expensive roof components (usually at the expense of the foam drain tray). For this reason you might want to reconsider using reinforced caps.
Be sure to check the drain trays to make sure they have not been compromised and I’d order two identical rods ensure symmetry.
Rgds, Fred
