Old 10-09-2018, 05:11 PM   #14
j.fro
Rennzenn
j.fro's Avatar
Tap water... Good question. No worries at all. When the engine is back together, fill with distilled water and run it a up to temp. Drain that and then fill with your coolant mix of choice. When the engine is apart, use compressed air to blow out the coolant passages in the block. The heads will by dry and clean.
Rennzenn
Jfro@rennzenn.com
