Old 10-08-2018, 10:40 PM   #39
Troy.Boxster
It's because of the low load of the high beam solenoid. If you want it to work properly with the fog lights as DRLs, you'll need to add a load resistor in parallel with the high beam solenoid (the same type of load resistor used to fix LED flashers).
This fools the car into thinking that a normal bulb is in the high beam socket.
Thanks Charles, you are a rock star! Perhaps I'll just use the LED spars I bought as DRLs and use the fogs as my high-beam flash when I don't have the headlights on.
2000 Boxster S - B.A.D. short shifter and intake plenum - 996 throttle body - Fred's xenon projector headlights - blue LED instrument cluster - and a few other things
Driving this car makes me wish I lived farther away from work!
Troy.Boxster is offline   Reply With Quote
