					Originally Posted by  particlewave
				It's because of the low load of the high beam solenoid. If you want it to work properly with the fog lights as DRLs, you'll need to add a load resistor in parallel with the high beam solenoid (the same type of load resistor used to fix LED flashers).
This fools the car into thinking that a normal bulb is in the high beam socket.
Thanks Charles, you are a rock star!
  Perhaps I'll just use the LED spars I bought as DRLs and use the fogs as my high-beam flash when I don't have the headlights on.
