Old 10-08-2018, 05:17 AM   #4
Oggie
Oggie's Avatar
Please excuse my ignorance, how will pressure testing locate the issue (genuine question)? I understand that you can pressure test the cooling system and if there is a leak the pressure will slowly go down. How would I locate where the leak is? Do I just assume that if, under pressure, no coolant is visible on the ground, it must be into the cylinders, thus it is the head?
I also know of chemical testers that can test the coolant for CO2 which can show if you have combustion gases seeping into the cooling system. Wouldn't this be a more useful test in this instance?
Asking this, as I am having a similar issue to the OP, but haven't yet replaced the Oil Cooler.
'99 base Boxster (Arena Red Metallic/Savanna Beige)
'02 911 Carerra Cabriolet (Arctic Silver/Metropole Blue)
Oggie is offline   Reply With Quote
