Old 10-04-2018, 10:50 AM   #2
911monty
911monty's Avatar
Originally Posted by Ottomotion View Post
I have seen a video of someone replacing the chain tensioners in car and am wondering if anyone has experience changing a broken spring in car?
Any helpful links also appreciated....
Thanks!
The answer is yes. You can use compressed air in the cylinder to hold the valve closed as you are removing the spring and keeper, however one inadvertent bump to the valve stem will result in losing air pressure and a dropped valve. Another method is to stuff the cylinder with rope then roll the piston up to hold the valve closed.
