Old 10-03-2018, 07:20 PM   #3
Gilles
QUOTE=dghii; Since you replaced your radiator, you absolutely must bleed the air out of your cooling system. The best thing to do would be to take it to a Porsche Indy and have them drain and fill your system using an air vue system.
[/QUOTE]
Dghii is right, you should Not drive your car after allowing air into the cooling system, an overheated engine is very expensive to properly repair..
