Old 10-03-2018, 06:31 PM   #2
dghii
The AC condenser is not your problem with overheating as no coolant runs through it.
Since you replaced your radiator, you absolutely must bleed the air out of your cooling system. The best thing to do would be to take it to an Indy and have them drain and fill your system using an air vue system.
The other thing you can due is pull up the bleeder valve in the trunk and drive your car (monitoring temps) for a few days to burp the air out. Need to keep an eye on coolant levels after a drive when car has cooled off.
dghii is online now   Reply With Quote
