Thread: Cross Drilled
Old 09-17-2006, 02:56 PM   #2
CJ_Boxster
Send a message via MSN to CJ_Boxster
Well I've heard that the factory boxter S cross drilled rotor and brake wear fast BUT if your rotors are aftermarket and your brake pads arent porsche pads then you might not have to replace the rotors every time you change the pads, if the brakes are made witha more less abbrasive compound like organic type then your rotors should last alittle longer.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
