Old 10-03-2018, 10:40 AM   #4
particlewave
Just a few questions;
What is the material used (you should be up front about this, as any manufacturer/seller would be)?
Since you're using heat to form these, what's going to happen when the fog lights are used (purposely or inadvertently) and heat builds up?
What about being left parked in the sun for extended periods?
Warping?
You haven't had them done long enough for any serious testing, so can you provide guarantees?
Those switchback LED strips use cheap LEDs that burn out prematurely (I know from experience)...will the strips be easily changeable when that happens, and for the $300 price tag, will you provide the replacements if/when they fail within a certain period?
If so, what would that period be?
The material looks thin and probably flimsy. How do you attach them and at what speeds will they be safe? Good for track use (120mph+)?
If they're attached well, how do you change the LED strip?
Your ad doesn't provide much detail.
