Old 10-03-2018, 09:53 AM   #1
911monty
911monty's Avatar
Fuel pump relay is likely to solve the problem. Bench test may not simulate the load. The fuel pump has minimum load when idling and goes to max load at full throttle. This is where most relays heat up and drop out. I may be opinionated due to old 911 days but a fuel pump relay was always carried as a spare. Good Luck
