Old 10-02-2018, 03:16 PM   #1
gharlowe
Blocked Convertible Drain
While trying to clear some debris from the convertible drain on the passenger side (beneath the foam catch basin), I inadvertently pushed it into the drain line itself. Unfortunately, it's a piece of round plastic that's a perfect fit for the drain hole. Needle nose pliers and a shop vac didn't work. I don't believe it can be pushed down all the way through the drain line so the drain line will have to pulled to clean it out.
I understand to remove the drain line, I'll have to access it through the rear tire well and remove the splash guards. Has anyone done this and are there any tips?
Thanks very much!
gharlowe is offline   Reply With Quote
