Old 10-01-2018, 11:28 PM   #10
Geof3
Regarding brake fluid, we are required to show proof the fluid has been changed/flushed annually prior to passing tech, assuming you are doing an HPDE. If you are, take your time and listen to your instructor. Learning the race line will be more beneficial than just about anything.
If you are simply doing a pick-up track day, just take it a bit easy to get comfortable, your stock gear will be fine as long as it is up to snuff.
I’m with Stone 100%, older good tires are generally going to be better than cheap new tires. If you want to do track days a good set of tires is well worth the investment, over almost everything else.
