Has anyone successfully installed H7 led replacement bulbs in your factory headlamp h
Hi all:
Did a bit of a search but found posts were older and had no solid information.
So I figured I'd ask the question, has anyone successfully installed H7 led bulbs in your factory headlamp housing?....
I looked at the eBay led headlamp offerings but 1st, $1k sound steep for that and 2nd, have read bad things, leaks, failed emitters, bad customer service, etc......
Let's keep on track here, I'm not asking about wether or not these bulbs should be used in factory housings, moral?, Legal?.....
I just want to know if anyone has done it, how did you do it, what did you use and do you like the results.
As always, please and thank you for your time.
Sent from my MHA-L29 using Tapatalk
