Old 09-28-2018, 09:10 AM   #11
JFP in PA
A few times in the past, when the gearbox simply does not want to move past the last inch, I noticed that rotating the crank slowly helps to synchronize the clutch disk with the transmission shaft..
When you are under there sweating and cursing, you will try everything ...LOL
Actually, because you are already at the gearbox, rotating one shaft flange while holding the other (in any gear) will accomplish the same thing.
