Old 09-26-2018, 07:08 PM   #24
Blackcloud
I aligned my center caps with the valve stem, as is correct for concours judging. Goes back in history for the point of the crest pointing to the valve stem so pit crew could find the stem immediately. How many of us are tall, and bent over to look for the valve stem? Depends on the type of wheel. Plus, if the center caps have been removed and swapped many times they can loosen up. The plastic ones will actually melt off the wheel under hot track conditions, and fall off.
Blackcloud is offline   Reply With Quote
