Old 09-24-2018, 06:31 PM   #2
aussieboxy
First and foremost: make sure you have the correct clutch.
I learned the hard way that the 5-spd clutch is different from the 6-spd. Same spline count, different diameter. Barely. So the input shaft wouldn't go in.
Once I had the correct clutch in, it sunk with a resounding "thunk".
I had the trans on a floor jack, balanced, and aimed it with my hand.
Yep it's the right clutch. Placed it on the spline before fitting
http://i13.tinypic.com/49ied5h.jpg
2000 2.7 Boxster
aussieboxy is offline   Reply With Quote
