Old 09-17-2006, 04:53 AM   #1
lewbo
Clutch vibration
Wondering if anyone can shed some light on this problem, when moving off from a stationery position I am feeling a slight vibration/shaking especially at low revs, sometimes feeling the same as I change into second, my initial thoughts where the clutch is about to die - I had a similar problem with my subaru turbo, I found out the problem there was due to moisture getting into the clutch after a few shifts the problem would go away, anyone else had a similar experience?
lewbo is offline   Reply With Quote
