Old 09-23-2018, 10:27 AM   #13
particlewave
Originally Posted by philipjayadler View Post
Never said I was taking it off. I follow the advice given in the "101 Projects" book.
24 mm socket turn clockwise to loosen.
Just to be clear...
When changing the belt, you don't remove or loosen the 24mm "nut". It's simply a grip point.
When you put pressure on the 24mm nut, the whole pulley swings to the side. This requires some force to move. I use a 2ft cheater bar.
Watch this: https://m.youtube.com/watch?v=YzIxv9aZGrY
