				Steering lock assembly bad.
			Well I thought my ignition switch failed so painstakingly replaced it. Put key in and all it does is doing back and forth still. Took paperclip to remove key cylinder and the parts inside the housing between the key and ignition switch are chewed up so how can I replace that whole assembly I haven't found a DIY for that part yet to try and attempt it. Otherwise I have a 2004 Boxter with a 3.2 newer engine for sale as a yard ornament since it's been sitting since November 2017 already.
