Old 09-22-2018, 10:50 PM   #1
Geof3
I want to go back and address the “can’t budge the nut on the tension wheel” statement. There is no reason to try to pull that nut, it’s fixed and the bolt comes through the back and is basically a stud. Can you clarify? The nut shouldn’t move at all and the tensioner should swing down without too much force. If your tensioner pulley will not move, that’s a bit of a problem and the tensioner needs to be replaced, and you don’t even want to know how much fun that is.
