Old 09-22-2018, 02:03 PM   #1
philipjayadler
Senior Member
Send a message via AIM to philipjayadler Send a message via Yahoo to philipjayadler Send a message via Skype™ to philipjayadler
Frozen Gas Pedal
This is kind of strange because I don't think what I did yesterday has anything to do with the problem I experienced today.
Yesterday, I did some routine maintenance on my 1999 Boxster. I changed the air filter. Added some hydraulic fluid [Pentosin CHF 11S], And tried to change the drive belt, but couldn't budge the nut on the tension wheel, so I left it for another day.
This morning I got in to the car only to find that my gas pedal was frozen. I couldn't push down on it. If I moved it a certain way [or my foot on the pedal] I could just push it down but the motion wasn't smooth, and there wasn't any resistance. Either the cable was stuck, or their was too much pressure/resistance to move it.
Driving the car was impossible. I opened everything up to retrace what I've done, but couldn't figure that anything I did would affect the pedal.
I went over the parts diagram, went to Bentley, started to research on line but their isn't enough on the subject, pedal mechanism, pedal to engine, how it works, etc. to even start to put scenarios together. Also I can't find enough on
even replacing the pedal [with another Porsche pedal, not a fancy Rennline].
Clutch and shifts are fine.
If anyone has run into this situation please help! I'm stumped and have no idea where to begin! Thanks!
philipjayadler is offline   Reply With Quote
