The car is running lean so it is either an intake vacuum leak or failed MAF sensor. You can rent a smoke tester at many auto parts stores and they work better than other shade tree methods.
If the MAF sensor is more than 5 yrs old I would change it.
Use an OEM fuel cap as many aftermarket caps do not seal completely.
