Me too!
After Autocrossing hard in hot weather exactly the same symptoms. I ended up replacing the latch (got the "new" one from Woody). Not a hard job at all and everything worked as it should at the next AX. Then this spring when I cleaned my radiators and put screens in the intakes I discovered that the right cooling fan wasn't working and replaced it. I believe the heat from the radiator with the bad fan contributed to the problem.
1941 Dodge Luxury Liner Coupe
