Sooooo...
Allow me to understand the functionality/purpose of the oil cooler...
This “receptacle” cools oil with air or coolant that runs through it?
If by coolant...Does the leak / intermix takes place when the o-ring leaks allowing fluids to mix or Oil cooler line/unit is punctured?
I guess my two other possible repairs could be:
Head gaskets...?
Head replacements...? Would bad compression be a sign?
Open your mind, and your eyes to the possibility that nothing is the way you believe it is. Your perspective is based on how you were taught to reason. Question everything, change nothing, enjoy the experience.
