Old 09-15-2018, 08:41 PM   #5
krazy-knuck
looks green and rubbery, hey - it's your variocam actuators if so. expensive to buy, and expensive to replace (engine needs opening). actually more expensive to fix than ims. run a magnet over it to confirm - if magnetic then engine probably done (symptom of metal on metal action - ims, but worn enough to have spit metal throughout the engine - good luck getting that out).
if actuators, engine can stay in the car if you take it to a tiny indy with tiny hands. otherwise any by the book porsche shop will drop engine and charge more $. total failure is not catastrophic put will produce a check engine light, loss of variocam action and loss of power. note that there is an actuator on each bank - check your cam deviation; big deviation on one side will let you know what side to replace.
OK, yes I just put a magnet on it and it doesn't pick it up and all the bits are green. What does these actuators do? Is my engine ok to still drive?
Thanks for all your help.
krazy-knuck is offline   Reply With Quote
